Use the following procedure to display the SPBM Service Instance Identifier (I-SID) information. The SPBM BMAC header includes an I-SID with a length of 24 bits. This I-SID can be used to identify and transmit any virtualized traffic in an encapsulated SPBM frame.
- Select SPBM.
- Select the I-SID tab.
I-SID Field Descriptions
Use the data in the following table to use the I-SID tab.
Name |
Description |
SysId |
Indicates the system identifier. |
Vlan |
Indicates the B-VLAN where this I-SID was configured or discovered. |
Isid |
Indicates the IS-IS SPBM I-SID identifier. |
NickName |
Indicates the nickname of the node where this I-SID was configured or discovered. |
HostName |
Indicates the host name listed in the LSP, or the IS-IS system. The IS-IS system name uses global system name, if the host name is not configured. |
Type |
Indicates the SPBM I-SID type; either configured or discovered. |
